Activity Forums Adobe Illustrator achieving specific texture
  • achieving specific texture
    Posted by John Kim on December 17, 2012 at 5:04 pm
    Hi, I am having trouble achieving a certain type of texture. I have tried using the grain filter in the options, but just doesn’t have the same feel. Help would be much appreciated.
    Here is a sample of the type of texture I am trying to achieve.
    Vincent Rosati replied 13 years, 8 months ago 2 Members · 1 Reply
  • Vincent Rosati
    December 28, 2012 at 2:59 am
    Would you simply be able to File / Place the tile raster image into your Illustrator file, than drag the tile into your Swatches palate to use it as a fill?
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
