Activity Forums VEGAS Pro Accidently this happened. How to fix?
  • Graham Bernard
    March 6, 2018 at 8:37 am
    If you are referring to the Zig-Zags, this indicates a changed Playback Rate. Did you want to change the Play Back Rate?
    * Grazie
  • Sandaru Dilshan
    March 6, 2018 at 8:57 am
    Thank You. Actually No. Video track somehow spited into two parts. Please check this image. I try to explain it bit clearly. https://i63.tinypic.com/29nvy29.png
    I want to rejoin two parts into single path again. But there is not two tracks. Just two rows on the same track.
  • Graham Bernard
    March 6, 2018 at 9:11 am
    [Sandaru Dilshan] “Video track somehow spited into two parts.”
    Understood – much clearer! You’re in Expanded Track Layer Mode – I never use it . . .
    Please read my responses here: https://forums.creativecow.net/readpost/24/1020721
    * Grazie
  • Sandaru Dilshan
    March 6, 2018 at 11:35 am
    You are awesome.! Thanks.
  • Graham Bernard
    March 6, 2018 at 12:06 pm
    [Sandaru Dilshan] “You are awesome.! Thanks.”
    Much praise indeed! ????
    * Grazie
