Activity Forums Apple Final Cut Pro Legacy accelerate audio
  • accelerate audio
    Posted by Jared Eaton on January 20, 2010 at 6:14 pm
    I want to accelerate the speed of an audio file in Final Cut. Is there a way to do this? I know I can adjust the speed of the file as a whole, but I would like to have the audio piece accelerate. any input would be great. Thanks!
    Jared
    Josh Olenslager replied 16 years, 8 months ago 2 Members · 1 Reply
  • Josh Olenslager
    January 21, 2010 at 3:35 am
    Use the blade tool to slice around the audio you want to change the speed on. Simply adjust inside the cut — it will be affected while everything outside the cut will remain normal speed. Note that as you change the audio speed the video / audio following it will slide as well.
    Josh
