Activity › Forums › Apple Final Cut Pro Legacy › ac3 sound disappears after 21 minutes
  • ac3 sound disappears after 21 minutes
    Posted by Nicholas Gray on March 31, 2010 at 8:02 am
    I am exporting a 1:50:28 long movie from FCP6, using Compressor, to DVDSP4. The m2v exports fine, but the ac3 file just goes dead silent after 21 minutes. Tried three times, always the same spot. Tried dumping the render files and re-rendering. Same result.
    Advice?
    Alexander Kallas replied 16 years, 6 months ago 3 Members · 3 Replies
  • Michael Gissing
    March 31, 2010 at 8:45 pm
    Did you try making the ac3 file on its own, not as it was also making the video? Try the audio as a separate encode (using the same start & end marks)
  • Nicholas Gray
    March 31, 2010 at 9:02 pm
    Thanks for quick response.
    Yes, I tried doing audio separately. (Actually was the first thing I tried.)
    I noticed the file size was 159MB, so I have to assume the data were in there somewhere. Tried re-installing DVDSP. That did nothing. Then tried re-installing Compressor and FCP. Doing a brand new render now, with my fingers crossed.
  • Alexander Kallas
    April 1, 2010 at 6:40 am
    Do an audio mix-down before export from FCP
    Cheers
    Alexander
