Activity › Forums › VEGAS Pro › AC3 audio volume
  • AC3 audio volume
    Posted by Sebastian Alvarez on January 3, 2008 at 3:17 am
    I noticed that when I encode audio to AC3 Pro in Vegas the level in the resulting file goes down considerably. I’m using the settings as they are, the only parameter I change is the bitrate to 448 kbps. Does anybody know why this happens?
    Sebastian Alvarez replied 18 years, 9 months ago 2 Members · 2 Replies
  • Mike Kujbida
    January 3, 2008 at 4:10 am
    I can’t explain the technical reason as to why this happens but here’s the workaround.
    Encode set to AC3 Pro;
    Click on Custom tab;
    On the first tab, set diag. norm to “-31”;
    On the last tab marked Preprocessing, set the Line Mode Profile and RF Mode Profile mode to “none”;
    Save this as a preset.
  • Sebastian Alvarez
    January 3, 2008 at 4:21 am
    Excellent. That worked. I wonder why they would set the default to parameters that produce such a level loss.
