AC3 Audio Tweak for Vegas Pro 9 (different than 8)
I’ve been using Vegas Pro 8c for some time and just upgraded to Pro 9. I’ve used the following audio tweak for AC3 in Pro 8:
Encode set to AC3;
Click on custom tab;
Dialog normalization: -31 dB;
Dynamic range compression: None;
On the first tab set diag. norm to “-31”;
On the last tab marked preprocessing;
Set the Line Mode & RF mode profiles to “None”;
Now save this as a preset.However, when trying to set up the same tweak on Pro 9, those same options don’t seem to exist. So is the default in Pro 9 basically the same as the above tweaked Pro 8 changes (which I’d like to keep)? Or if not, how do you tweak Pro 9 to be the same?
