Activity Forums Maxon Cinema 4D About unnecessary points
  • About unnecessary points
    Posted by Anthony0905 on January 14, 2006 at 7:30 pm
    Hello world!!!
    I use Cinema 4D release 8. I’m trying to design my kitcen as a practice so as to learn more about C4D. I use booleans in order to make gaps on a wall. This method produses many polygons. Does anyone have any idea of how can i reduce the size of the model? Is there any choise such as “delete” or “clean up unnecessary points or edges”?
    Thank you,
    Anthony
    Anthony0905 replied 20 years, 7 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    January 16, 2006 at 5:42 am
    You could make the boolean editable and try the poly reduction object (in the deformers section). R9 has a “better bool” option that usually results in less chaotic geometry. I think it may have been available as a free R8 plugin (from Maxon), but I could be wrong about that.
    Or better yet, don’t use booleans at all unless you really have to. See if you can get along with the knife tool.
  • Anthony0905
    January 18, 2006 at 10:03 am
    Thank you for your advise. I’m going to try it and i ‘ll inform you.
    Anthony
