Activity › Forums › Maxon Cinema 4D › About materials and textures (new guy)
Posted by Carlos Angulo on November 9, 2006 at 5:42 pmHi,
IMylenium replied 19 years, 10 months ago 3 Members · 2 Replies -
Philo Calhoun
November 9, 2006 at 9:14 pmIn the material for your pavement lines add the pavement line image file under colors. In photoshop, create an alpha channel where you want the underlying texture to show and give this file a name. In new material for the pavement line, select this alpha channel file under “alpha channel”. It will allow you to “see through” these areas to your underlying texture.
Mylenium
November 10, 2006 at 7:02 amIf your lines are strictly b/w, the simple soution would be to just enable the “mix textures additively” option on the second material. You should also consider using a layer shader and a single material for the entire road.
Mylenium
[Pour Myl
