About masking..
Posted by Johanna Reilson on February 2, 2010 at 4:57 pmHi.. i have a question about masking in Sony Vegas Pro 8.0
If i have already done the mask and stuff.. is there possible to move that ? .. i mean.. like when masking object is in the middle, then can i move it to the left.. so it will stay on left .. ?
if anyone can do that, then please help 🙂John Rofrano replied 16 years, 7 months ago 2 Members · 5 Replies -
John Rofrano
February 2, 2010 at 5:40 pmIf you used the Mask tool in Pan/Crop, all you have to do is right-click on one of the points and choose Select | All. Then move the mask to wherever you want by dragging one of the selected points (make sure you use the Arrow tool to drag).
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Johanna Reilson
February 2, 2010 at 6:00 pmactually.. i ment .. how i can move the selected area WITH that picture , what i had pointed all over ..
and if i make these anchors , then how i can move them correctly.. always when i try to move them, it’s goes all messy and not how it suppose to be :S -
John Rofrano
February 3, 2010 at 12:56 pmwhen i try to move them, it’s goes all messy and not how it suppose to be
It sounds like you are not selecting the Arrow tool. If you have the point tool selected it will change the mask points.
Try this:
- Select the Arrow tool
- Click on an area that is not within the mask (this will deselect the mask)
- Now click on one point and choose Select | All
- Click that same point and move the mask.
This should move the mask without changing it.
~jr
Johanna Reilson
February 3, 2010 at 2:16 pmi know already that 🙂 ..
but i want to move one or two points.. but it don’t go the way i want.. it goes always more or less.. but not strictly … -
John Rofrano
February 3, 2010 at 6:06 pmbut i want to move one or two points.. but it don’t go the way i want.. it goes always more or less.. but not strictly
Could it be that you have Enable Snaping depressed? If so, the points will only move to grid positions. Try turning this off in the buttons on the left or hold Shift to temporarily override.
~jr
