Activity Forums Adobe After Effects About keying; Shall I have to roto these regions?
  • About keying; Shall I have to roto these regions?
    Posted by Mostafa Talebi on September 15, 2011 at 1:04 pm
    In the image below( which is a part of a 478-frame footage) I have marked two areas about which I’m a bit vague. In the Chroma-set there are many extra equipment and during some frames the main character even overlaps some parts which were never to get included in final keyed footage. Thus I think I have to mask the character and do some rotoscoping so that at final stage only the character is keyed and all other elements are suppressed out. Am I correct?(below is the footage’s one solo frame)
    Ben G unguren replied 14 years, 12 months ago 2 Members · 1 Reply
  • Ben G unguren
    September 15, 2011 at 1:42 pm
    Yup — those areas need to be removed by hand. Which, when you consider how much you don’t need to roto, is a great deal.
    Occasionally you can use a difference matte key to remove non-green background elements, but that works best when they are very different from the foreground (in your case, there’s a lot of dark colors in there — best to go with the roto).
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
