Activity › Forums › Apple Final Cut Pro Legacy › Abort capture and batch capture questions
  • Abort capture and batch capture questions
    Posted by Leonard Frankford on November 25, 2009 at 5:45 pm
    I have two questions about capturing in FCP:
    1. How do I abort capture without saving the captured media? Escape stops the capture, but it always saves it. Sometimes I want to just abort. I can’t find a setting to change this.
    2. I want to set up a batch capture where some clips will have audio and video, and some clips will have video only (b-roll). I noticed when I changed the capture settings to video only, it didn’t understand that I wanted those clips only to be video only, and the rest audio/video. Is there any way to do this in Final Cut? Thanks.
    Leonard
    Leonard Frankford replied 16 years, 10 months ago 3 Members · 4 Replies
  • Rafael Amador
    November 25, 2009 at 6:32 pm
    Hi Leonard,
    The answer in both cases is no.
    I haven’t heard of a way to stop capture and delete the clip at the same time.
    About the audio/video capture, there is not a way to set different capture settings in the same batch.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Arnie Schlissel
    November 25, 2009 at 10:57 pm
    [Leonard Frankford] “2. I want to set up a batch capture where some clips will have audio and video, and some clips will have video only (b-roll). I noticed when I changed the capture settings to video only, it didn’t understand that I wanted those clips only to be video only, and the rest audio/video. Is there any way to do this in Final Cut?”
    Yes, you can do this in Final Cut. Briefly, you can set the audio & video tracks for each clip you log, there’s a tab in the Log & Capture window where you do this. You can also change those settings in the browser window before you capture. For more details, check your manual.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Rafael Amador
    November 26, 2009 at 2:17 am
    [Arnie Schlissel] “Yes, you can do this in Final Cut. Briefly, you can set the audio & video tracks for each clip you log, there’s a tab in the Log & Capture window where you do this. You can also change those settings in the browser window before you capture. For more details, check your manual. “
    Right Arnie.
    I’ve to stop posting late at night.
    Cheers,
    rafael
  • Leonard Frankford
    November 30, 2009 at 5:01 pm
    Yes, it works when I select Log Clip while I’m still in the Settings window. Thanks.
    Leonard
