Activity › Forums › Adobe Premiere Pro › AAF of jpegs from avid to premier pro makes Insert Editing go kaplooey
  • AAF of jpegs from avid to premier pro makes Insert Editing go kaplooey
    Posted by John Hill on June 14, 2017 at 3:38 pm
    I imported an aaf from Avid and the video clips came in fine but the jpegs were each 12 hours long, although I had set Still Duration in Premier for 5 seconds (they were 5 seconds long on the Avid timeline as well).
    Also when editing the jpegs I was only able to overwrite them. Insert Editing was greyed out.
    If I drag the jpegs from the drive into Premier, I can insert edit (but they’re still 12 hours long).
    Anyone else suffer from this malady?
    John
    Jerry Wise replied 9 years, 3 months ago 2 Members · 1 Reply
  • Jerry Wise
    June 14, 2017 at 4:28 pm
    yep…you have to click on each one and in the “Source” window hit “Clear In and Out”
