Activity Forums DaVinci Resolve AAF Import Swapping Incorrect Clips
  • AAF Import Swapping Incorrect Clips
    Posted by August Bradley on March 15, 2013 at 8:34 pm
    When I import a project sequence via AAF into Resolve, clips in the timeline are being arbitrarily swapped with other unrelated clips. This is affecting about 20% o the clips int he sequence.
    In some cases the clips being incorrectly swapped-in are coming from different shoot days, and different folders in Resolve’s Media Pool, and in other cases coming from the same shoot day and Media Pool folder as the clip that should be in the sequence. Many of the clips being incorrectly swapped-in are not even in the cut (they’re unused takes from the shoot).
    It’s a single track import. All filenames are unique, no duplicate names.
    Working with Resolve 9.1.1 on Mac OSX 10.7.5. Exporting AAF from Avid Symphony 6.5.
    I’m really stuck, any advice on what could possibly be causing this?
    Thank you!
    Andrew Gleeson replied 11 years, 9 months ago 3 Members · 6 Replies
  • Jean-baptiste Perrin
    March 16, 2013 at 5:41 pm
    Does your video files are imported into AVID as MXF video files or are they linked by AMA?
    March 16, 2013 at 6:04 pm
  • August Bradley
    March 16, 2013 at 8:31 pm
    The video files were imported into Avid as MXF (converted from the raw files in Redcine X).
    March 16, 2013 at 9:58 pm
    Are you trying to relink to raw files into davinci or not? If you don’t need to, try consolidate your sequence onto a new disk, use these new files for your aaf and send to davinci.
  • August Bradley
    March 16, 2013 at 10:34 pm
    Yes, need to re-link to the original raw files for the grade.
  • Andrew Gleeson
    December 5, 2014 at 1:56 am
    Having an identical problem. August, any developments?
