Activity Forums DaVinci Resolve AAF import issue – clips with offset
  • AAF import issue – clips with offset
    Posted by Tina Hedegaard on April 3, 2012 at 9:59 am
    Hello
    I’ve experienced some issues when I import an AAF into Resolve.
    Specs:
    AAF with link to media from Avid 5.5.3
    There is only one video track and no dissolves or effects
    The project.
    1080p 25fps
    DNXHD 120
    Multicam – which has been committed
    Shot on: Sony PDW-700 / XDCAM
    DaVinci Resolve 8.2
    Media: DNXHD 120
    The import goes smoothly and all the media is reconnected, a lot of the clips has though an offset of 1-2 frames. I see this when I use the mixed vipe and match up my reference video and the timeline in Davinci. This means that I have to manually move almost every clip 1-2 frames to get it in the correct spot.
    What I’ve tried so far.
    In Avid
    – AAF with consolidated media
    – AAF with protocol, Marks, selected tracks
    – I even tried to make an AAF of the timeline before it was cleaned up to one track – I am actually glad this didn’t work.
    – EDL – that didn’t work at all
    In DaVinci
    – Started a new project and added the media to the media pool again
    Any suggestions would be appreciated
    Yours Sincerely
    Tina Hedegaard
    Editor | Final Cut Pro 7 | Media Composer 5.0 -5.5
    Mac OS 10.6.7
    Knut Jansohn replied 14 years, 5 months ago 2 Members · 3 Replies
  • Knut Jansohn
    April 3, 2012 at 8:17 pm
    Hi Tina,
    [Tina Hedegaard] “There is only one video track and no dissolves or effects”
    in this case a simple edl should do the job very well.
    I havn’t any idea about your reported issue, but edl (cmx 3600) should give you a perfect conform – if not you might check your offline/reference.
    What does it mean “- EDL – that didn’t work at all”?
    All the best.
    K.
    [Tina Hedegaard] “- EDL – that didn’t work at all”
  • Tina Hedegaard
    April 4, 2012 at 9:38 am
    Hello Knut
    Thanks for your response.
    What I meant with “EDL – that didn’t work at all” is that I tried to make an EDL CMX 3600 and when I imported it in DaVinci then there was a conflict on each clip, so I had to choose the right clip for each clip. I also tried to make an EDL (I can’t remember the name) that is used to RED material with room for long reels. But it was the same.
    I’ve made both the EDL, AAF and the reference from the same sequence – though the reference had audio as well
    Yours Sincerely
    Tina Hedegaard
    Mac OS 10.6.7
  • Knut Jansohn
    April 4, 2012 at 10:06 am
    Have you checked the timeline conform options in project tab?
    This should help you out and is very well described in the manual.
    Also checking ‘extract reel names from edl comment’ in settings tab could be usefull.
    No reels no fun 🙂
    Best
    K.
