Activity Forums Adobe Premiere Pro AAF Import From Avid MC 5.5.1 Causes PPro to Crash
  • AAF Import From Avid MC 5.5.1 Causes PPro to Crash
    Posted by Lindsay Simpson on April 6, 2011 at 5:22 pm
    Hi all,
    We are in the process of dumping our Avid system and switching to primarily Adobe production. This feature came to my attention:
    https://tv.adobe.com/watch/adobe-presentations-2009/open-workflows-betw een-avid-and-adobe-cs4-production-premium#transcription-request
    And I thought it would be a great solution to the daunting task of getting our media out of Avid MXF and stored in a user-defined manner. I was able to successfully export a DV 25 MXF based sequence in Avid to an AAF file. I was able to get it imported into Premiere and view the clips and sequence in the browser window. I was even able to open the sequence created by the AAF in PPro thought it did not include any video tracks. When I drag, drop clips from the AAF import they do open in the sequence with video and audio. I tried exporting a short DV clip to Quicktime and AVI and was able to get as far as AME, but after clicking ‘Export’ it was only a few moments before PPro crashed. IF it can’t handle DV clips, I’m not sure how to go about our HD files, might need some 3rd party software after all.
    We are currently running MC 5.5 and PPro CS5 on the same tower as we only currently have access to capture or dump to tape through Avid based on our Avid specific Nitris DX A/D breakout box. (we are looking at options for a PPro compatible breakout box, but interim will need to capture/dump through MC). Perhaps having the two software apps on the same tower is bogging things down? Only PPro is running and open when I’ve tried these exports,etc.
    Thanks for any input,
    Lindsay
    Tim Kolb replied 15 years, 5 months ago 2 Members · 1 Reply
  • Tim Kolb
    April 7, 2011 at 12:09 am
    The first thing i wonder about is whether or not PPro can access the Avid codecs. Avid has their codecs available for generic installs on systems without an Avid software/hardware product that need to use Avid assets…
    Maybe try installing the Avid codecs and see if Premiere Pro can access them?
    …you’d need them on the system after you move away from the Avid anyway, and until you have another capture option, all your media will be Avid…
    TimK,
    Director, Consultant
    Kolb Productions,
