Activity Forums Adobe Audition AAF Import-Adobe says yes, reality says no
  • AAF Import-Adobe says yes, reality says no
    Posted by Rojan_man on January 1, 2007 at 7:42 pm
    Adobe’s website clearly states that it accepts AAF Imports. I have included a link to the page that says so, along with the portion that does. Yet, I have an embedded AAF file, and it will not accept the import. Am I doing something wrong, or is Adobe wrong?
    “AAF and EDL import/export
    Exchange project metadata with major video, film, and audio applications via industry-standard Advanced Authoring Format (AAF), AAF with Edit Protocol, and Edit Decision List (EDL) files.”
    https://www.adobe.com/products/productionstudio/overview2.html
    Michael Rooney replied 17 years, 4 months ago 4 Members · 3 Replies
  • Willie Toth
    January 1, 2007 at 8:43 pm
    When you first install the program you have a page that comes up and it shows you what file extensions Audition will look at … There are defaults but some of them you have to select at that time … I always select the “all” option … I suspect that this is your problem so I would uninstall and reinstall and when this page comes up I would select the all option ……. WILLIE
  • Durin Gleaves
    January 26, 2007 at 11:40 pm
    Hi Rojan_Man,
    The section that describes the EDL and AAF import functionality is labeled as part of the Premiere Pro functionality. Premiere Pro can import EDL and AAF files for use in video projects, but these aren’t features currently supported in Audition.
    You could open these in Premiere Pro, then use the “Edit in Audition” command to work on the specific audio data, however.
  • Michael Rooney
    May 5, 2009 at 3:40 pm
    For import & export functionality including EDL & ADL to and from Adobe Audition you should probably check out this site.
    https://www.aatranslator.com.au
