Activity › Forums › Avid Media Composer › aaf exporting all media
  • aaf exporting all media
    Posted by Len Hugh on May 12, 2011 at 2:39 am
    Is there a way to export all audio that relates to an audio file, even if its not in the sequence?
    Reason being is editors often cut with 1 mix track provided from the recordist and the split tracks for each mic are discarded when syncing and making their subclips.
    Then when it comes time for delivering to sound they want to have all the split tracks.
    The only way I know of is to matchframe back to the original and cut back in… boring.
    thanks
    Len Hugh replied 15 years, 4 months ago 3 Members · 3 Replies
  • Job Ter burg
    May 12, 2011 at 9:58 am
    If you take that AAF into PT and add all the original source files (BWAVs) into the same session, PT can expand each region with all the source tracks.
    Unfortunately, there’s no easy way to do it in MC. Longstanding feature request.
  • Andrew Rendell
    May 15, 2011 at 10:38 pm
    You should tell your editors to track lay properly as they go. It’s not hard – I do it all the time. I’ve had to pick up a job from another editor a few times and occasionally pass things over to another editor for something I’m cutting and it irritates the hell out of me if they don’t tracklay the way I want it.
  • Len Hugh
    May 19, 2011 at 5:21 am
    thanks guys, and yes it would be nice if editors would do this but at the end of the day being the assistant means I have to make there job easier, you know how it is 🙂
