Activity Forums Adobe After Effects Expressions A word doc to after effects
  • Dan Ebberts
    February 21, 2012 at 9:03 pm
    If you convert it to a plain text file, you could read it with a script. Reading the file is pretty easy, but what you do with the text is the tricky part.
    Dan
  • Kevin Camp
    February 21, 2012 at 10:20 pm
    if you just need it as a list (ie, you don’t actually need separate text layers to manipulate in ae), then you could create pdf of the doc and import the pdf in as a layer to manipulate in ae…. obviously any formatting to the text would need to be done prior to making the pdf…
    harry frank did a tutorial on getting text from an external file into ae (for lowerthirds) here:
    https://www.graymachine.com/2009/03/expressions-and-external-documents/
    he also links to a followup to it.
    there’s also the copy/paste option from word to ae. it just comes down to what you need.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
