Activity Forums Avid Media Composer A way to use ScriptSync you might not have tried before.
  • A way to use ScriptSync you might not have tried before.
    Posted by Andy Crow on December 4, 2009 at 7:57 pm
    I had a project recently where my client had a bunch of clips (each several minutes long), say 15 of them. Then they wanted to pull JUST the part where their product is mentioned and make a montage of those. So we’d have 15 different people saying “ProductX,ProductX,ProductX,ProductX,ProductX,ProductX,ProductX” all one on top of the other.
    Rather than going through and listening to each clip individually I made a new .txt document with ProductX repeated several times, each on its own line, and imported that into the project as a New Script.
    I then took each clip, laid it against the script and performed the ScriptSync. Then I simply subclipped out each mention of ProductX into a separate bin. Deleted the take from the script and added the next clip and redo the ScriptSync.
    I’d guess the whole process went 3 or 4 times faster than going through each clip individually at 2x speed which is the method I probably would of used had I not tried ScriptSync.
    I was really pleased with the results, and thought I’d pass it along.
    Happy Holidays,
    ac
    Chris Bové replied 16 years, 1 month ago 3 Members · 2 Replies
