Activity › Forums › Avid Media Composer › A way to transcode to Avid DNxHD without avid MC?
Posted by David Glasgal on March 13, 2012 at 11:04 pmI want to take a bunch of quicktime footage (from HVX, 7D, GoPro, etc) and transcode it to Avid DNxHD 175x. The problem is I don’t have an avid available. I like how Red Cine X does it for Red files and was wondering if there was a cheap or free program that did it for other flavors of video? Anyone? Thanks
David
Chris Harlan replied 14 years, 6 months ago 8 Members · 14 Replies -
Shane Ross
March 13, 2012 at 11:41 pmAll you need to do is download the Avid codecs….
https://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=392959
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Mike Most
March 13, 2012 at 11:43 pmIf you want to make Avid MXF files, you can use Resolve Lite. It’s free.
David Glasgal
March 13, 2012 at 11:44 pmwhen i do that, i still have to “import” the file into avid. With the Red Cine program, i just put the mxf files into the mxf folder and they link up. do you concur?
David Glasgal
March 13, 2012 at 11:54 pmok i’ll download that now. Is it easy to do? i’ve never used resolve. thx
Shane Ross
March 14, 2012 at 12:44 amSorry, I don’t know the Red Cine program, and if it makes MXF files or QT files in the DNxHD format.
Shane
Little Frog Post
Pat Horridge
March 14, 2012 at 8:23 amAlthough it’s quick to just drop externally made MXF files into the Avid mediaFiles MXF folders just be aware that the media has no project metatdata so the Avids Media tool will fail to see that media associated with any Avid project making the use of the media tool less helpful.
The prefered method is to AMA and then Transcode to make the Avid media. But you need MC of course.
Also there’s a need trick (unsupported) to get all the clips from a bunch of MXF files into a bin.
After you drop the new MXF files, externally created, into the Avid mediaFiles folder and let MC launch and scan them (to build the databases) at explorer/finder level find the file in that foldr Avid will have created called msmMMOB.mdb and drag and drop it into an empty Avid bin inside MC while it’s running and it will be populated with all the clips in that MXF folder.Pat Horridge
Technical Director, Trainer, Avid Certified Instructor
VET
Production Editing Digital Media Design DVD
T +44 (0)20 7505 4701 | F +44 (0)20 7505 4800 | E pat@vet.co.uk |
http://www.vet.co.uk | Lux Building 2-4 Hoxton Square London N1 6US -
Peter Groom
March 14, 2012 at 11:46 amThis is interesting.
Am I right in thinking that externally created avid HDxND files (say from resolve lite) would fast import.
PeterPost Production Dubbing Mixer
Pat Horridge
March 14, 2012 at 12:10 pmYes they should. But I’d just AMA to them. No need to make yet more media!
Pat Horridge
VET
Mike Most
March 14, 2012 at 3:10 pmIf you’re making MXF files in Resolve, there is no “import.” Put them in the right place (Avid MediaFiles/MXF/numbered folder), let Avid scan the drive, and drag the .mdb file into a new bin. It’s only if you make DNx encoded Quicktime movies that you need to go through an import process.
David Glasgal
March 15, 2012 at 6:53 pmit says, “Remember that Avid MXF support is an extra purchase for Resolve in the Avid File Support option.”
