Activity › Forums › Adobe Premiere Pro › A way to copy the project name (not a clip name) in Premiere Pro?
  • A way to copy the project name (not a clip name) in Premiere Pro?
    Posted by Amy Young on November 21, 2016 at 6:19 pm
    I see this: “The effect has been added for Premiere Pro CC: just search the Effects tab for “Clip Name”. Drag it onto any clip and the file name is automatically displayed for burn-in.”
    But I want to copy the project name (or file name) with the full path as plain text to the clipboard. I am keeping a spreadsheet of the file names and sequence names, but getting the filenames out of PPro seems hard. I can -see- it all over the place, but I can’t copy the name from a tool tip, for example.
    Or another strategy, to access PP’s list of recent files, in some selectable way.
    Thanks for any ideas!
    Amy Young replied 9 years, 10 months ago 2 Members · 2 Replies
  • Joe Barta iv
    November 25, 2016 at 6:15 pm
    This is from C-Net and it works for getting the full path name as text that can be copied, if that helps.
    “Open a new Finder window by pressing Command-N, and then press Shift-Command-G to reveal the Go to Folder panel for the new window. Then drag a target file from another window to the Go to Folder text field, where it will be converted to a full text path that you can select and copy.”
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
  • Amy Young
    November 25, 2016 at 7:10 pm
    Thanks Joe!
    Another way I do it (outside of PP) is to open a Terminal window and drag the file there, where it will display the full path. But I was wondering if I could stay in PP and get the full path on a clipboard. Because from there, I want to paste into a spreadsheet of my sequences and projects (it’s a really large project). To get the sequence name, I can “rename” or click on it and press Return, then copy the name. But the project name seems elusive!
