Activity › Forums › Adobe After Effects › A tutorial is missing a part; anyone an idea how to create this?
  • A tutorial is missing a part; anyone an idea how to create this?
    Posted by Johan Frijhof on November 1, 2020 at 4:59 pm
    Hi all!
    So, I am trying to learn After Effects and I am getting there. I follow tutorials and try to bend them to create my own stuff.
    I have found this tutorial: https://www.youtube.com/watch?v=KqitH2n5gF0&t=31s
    Pretty cool, and apart from the smoke (which you have to pay for) it works on my machine. But… Around 0:39 there are these flashes and the uploader forgot (yeah, let’s put it like that) to explain how to create those. I really like that effect.
    So, as you might have guessed; how can I create these flashes? Can anyone explain this or share a link where something like this explained?
    Thanks you so much!
    Johan Frijhof replied 5 years, 11 months ago 3 Members · 3 Replies
  • Eric Santiago
    November 1, 2020 at 11:11 pm
    Might need better lens flare options like Video CoPilots.
    That’s all the are, just lens flares.
    You can even recreate a frame in PS and just flash them in short bursts frames to match.
  • Brendon Murphy
    November 1, 2020 at 11:28 pm
    Here’s one way using built in effects.
    WARNING – FLASHING GRAPHICS BELOW
    Create a black solid and add the “Lens Flare” effect. Move the Flare Center to the far left side of the screen.
    Add a gaussian blur… let’s say 200 for the blurriness. Check “Repeat edge pixels”.
    Add a glow. Let’s say 260 for radius.
    Duplicate the layer. Move that flare to the right side. Set the blending mode of the top one to “Add”. Add a white solid to the top of the comp at 10% opacity for a general wash, set it to “add” as well.
    Precompose those three layers.
    Set the precomp blending mode to “Add”.
    Add a tint effect to the precomp. Change the black color to a saturated blue.
    Add a levels or curves effect, and animate the brightness along with the opacity of the layer.
  • Johan Frijhof
    November 2, 2020 at 7:42 am
    Awesome short explanation. Took me just 10 minutes to figure it out and I think I have something I can use in my project.
    Thank you for the quick reply and the clear explanation. I’ve learned a lot!
