Activity Forums Apple Final Cut Pro Legacy A stack of white plates
  • Jeremy Garchow
    December 17, 2010 at 1:48 am
    [Lisa Koza] “Here is a little clip. This was done with dropping my HDV footage right into an SD sequence.”
    But it’s recompressed to h264.
    You need to upload a few seconds of full resolution/codec footage. Did you read that other thread at all? It’s like deja vu.
    Jeremy
  • Lisa Koza
    December 17, 2010 at 1:58 am
    oh crap, sent the wrong one. I need a vodka, and fast. I’m so sorry.
  • Jeremy Garchow
    December 17, 2010 at 1:59 am
    No worries. Just zip a few seconds of a full codec file.
    I’ll take a gin and tonic, please.
  • Lisa Koza
    December 17, 2010 at 2:45 am
    Vodka cranberry is where I’m at.
    1412_andretti.mov.zip
  • Jeremy Garchow
    December 17, 2010 at 2:57 am
    ok, now you have to do me a favor. upload 2 seconds of raw footage.
    Make a new sequence, drop an HD clip in to it from your Browser, hit yes when FCp asks if you want to accept the sequence settings, then export 2 seconds of it. Zip it, then upload.
    Are you trying to make a ProRes or DV movie? Did you try using Compressor yet?
  • Lisa Koza
    December 17, 2010 at 3:07 am
    It was a 4 cam shoot, all HDV Sony’s however. This is from just one cam.
    1413_test.mov.zip
    thank you again, gin on it’s way! 🙂
  • Jeremy Garchow
    December 17, 2010 at 3:26 am
    OK. That cli is definitely straight up 1080i.
    This is what you need to do. In your HD sequence, make sure the sequence is set to Upper Field First.
    Render.
    Export a reference movie (File > Export > Quicktime Movie, leave recompress and leave self contained UNchecked).
    Open Compressor.
    Bring the movie in to Compressor.
    Now. more questions.
    What do you need, do you need a center cut dv movie? Anamorphic Prores movie? What is your master supposed to be?
    Jeremy
  • Lisa Koza
    December 17, 2010 at 3:33 am
    I need to deliver SD in a 4:3 to a local TV station, they didn’t specify format. I have several sections to this 28:30 min show. I have 4 sequences in HD, the guts of the show (the clip is an example that I sent you). Then I have a bunch of graphics for sponsored by ads, they are a mishmash of HD and SD. Then I have a few commercials from other companies, all in SD. So, my timeline to go OUT I made in SD, NTSC DV/DVCPRO. I decided to stay away from ProRes after you mentioned that 486 business.
    So, if I export out, then into compressor……it needs to play happy with all the other formats. I’ve been editing for over 4 years now, but have never had a mix format project like this. A great learning experience!
  • Jeremy Garchow
    December 17, 2010 at 3:34 am
    is everything 4×3 safe?
    You don’ t know if you’re delivering tape or file?
  • Lisa Koza
    December 17, 2010 at 3:44 am
    Delivering Tape.
    Everything is Title Safe. Going letterbox in a 4:3.
Page 2 of 3
