Activity Forums Adobe Premiere Pro A serious error ocurred that requires Adobe Premiere to shut down
  • A serious error ocurred that requires Adobe Premiere to shut down
    Posted by Ana Innoranti on December 17, 2009 at 10:34 pm
    That message appears when I try to open Prem CS4, what could it be?
    I have work with it several times and that never happened before.
    Thanks.
    Ana
    Dave Graton replied 16 years, 9 months ago 2 Members · 1 Reply
  • Dave Graton
    December 23, 2009 at 7:32 am
    I had the same problem with CS3 and their latest patch fixed it (finally). It had to do with scrubbing over badly captured frames.
    If you’re having the problem with starting Premiere to the intro/start screen then you may have to reinstall Premiere; Otherwise, if you launching from a Project file then your project is likely corrupted and you should look in your Auto-Save folder and try opening up a slightly-older version.
    Good luck.
