Activity Forums Apple Final Cut Pro Legacy A real hard nut to crack!
  • A real hard nut to crack!
    Posted by Sascha Engel on August 28, 2013 at 2:00 pm
    Most bizarre Problem I ever encountered on FCP: A friend of mine is editing his Docu in FCP, now he got the music back from the Sound Designer, dropped the WAV on the TL and the beginning is sync, but in the cause of the film length of 12min, it slowly runs out of sync.
    On the sound editors machine all was synced up.
    So, we checked on my system, hooked up his external HD and opened the project on my Mac. The same project with the same source files suddenly is sync from beginning till the end.
    So, I saved the project on my machine with Save As and opened that project again on his computer and:Again, it starts to run off sync during the film – about 8 frames.
    Any idea what this can be?
    Greetings,
    Sascha Engel
    TIME BANDITZ Productions
    http://www.youtube.com/taikang
    Sascha Engel replied 13 years ago 7 Members · 16 Replies
  • 16 Replies
  • Mark Suszko
    August 28, 2013 at 2:48 pm
    Final Cut prefers AIFF files to WAV.
  • Sascha Engel
    August 28, 2013 at 3:24 pm
    Can’t be the reason. For one we also tried with AIFF. and second: the exact same project played just fine on another MAC with FCP.
    Sascha Engel
  • Mark Suszko
    August 28, 2013 at 3:25 pm
    audio sample rates in agreement?
  • Rainer Wirth
    August 28, 2013 at 3:56 pm
    How do you monitor the stuff?
    Through a breakout box or directly from the computer? Some breakout boxes and tape decks need sync such as a blackburst signal.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Sascha Engel
    August 28, 2013 at 3:58 pm
    Yes, on both computers, same sample rates.
    Sascha Engel
  • Sascha Engel
    August 28, 2013 at 3:59 pm
    On both computers, we watched the material over the DVI connected computer monitor, not over a broadcast screen.
    Sascha Engel
  • Rainer Wirth
    August 28, 2013 at 4:05 pm
    Settings inside FCP?
    For example frame settings?
    Cheers
    Rainer
    factstory
    Rainer Wirth
    Mac pro 8core
    Adobe,FCP,Avid
  • Sascha Engel
    August 28, 2013 at 4:35 pm
    What do you mean? On both computers we used the same project and therefor the same project settings: apple pro res, HD, progressive, 25p.
    Sascha Engel
  • Mark Suszko
    August 28, 2013 at 4:44 pm
    Somewhere that’s too obvious to notice, a setting is different and causing the drift. I’ll bet a virtual donut on it.
  • Shane Ross
    Trash preferences on the machine where sync is an issue.
    Shane
    Little Frog Post
