Activity Forums Adobe Premiere Pro A question about converting my old PAL DV movies into digital
  • A question about converting my old PAL DV movies into digital
    Posted by Jon Wendz on November 5, 2016 at 8:35 pm
    Hi all, I’m a bit of a newbie here and I’m hoping someone may be able to help me in my latest venture.
    I have a load of old family videos which I really want to digitise and upload to YouTube for the family for a special Christmas surprise!
    I’ve already done the most painful bit, and captured all of the footage onto my PC: Sony DV Handycam->Firewire->PC. Now my 2TB HDD is short on space for the first time ever ?Digression aside, each of the ‘raw’ avi files are huge, with properties of 720×576 @ 25fps. I’m using Premiere Pro CC 2017 and have been encoding to HEVC (H.265).
    Here’s the issue (and I’ve spent a while researching prior to asking this) what’s the deal with the frame rate on export? It doesn’t look right at all. What I’ve learned is that the raw footage from my DV camcorder is interlaced and the top and bottom fields have been compressed into a single frame when I export? In Handbrake for example there’s a ‘bob & weave’ export facility which on compression looks pretty much 1:1 with the original and ends up at 50fps. I don’t however see such an option in Premiere Pro. I can change the framerate to 50 fps on export but I don’t think it’s doing what I want it to do.
    Does anyone have a tried and tested method of exporting the classic DV goodness from it’s avi original into a compressed, clean mp4 (or similar) output directly from PP? Many thanks all ?
    As a side note, the raw avi shows these properties (don’t know if they are of any use)
    Cheers, Jon
    Format: AVI
    Format/Info: Audio Video Interleave
    Commercial name: DV
    Format profile: OpenDML
    File size: 12.9 GiB
    Duration: 1h 0mn
    Overall bit rate mode: Constant
    Overall bit rate: 30.4 Mbps
    Recorded date: 1999-06-25 20:50:06.000
    Video
    Format: DV
    Codec ID: dvsd
    Codec ID/Hint: Sony
    Duration: 1h 0mn
    Bit rate mode: Constant
    Bit rate: 24.4 Mbps
    Encoded bit rate: 28.8 Mbps
    Width: 720 pixels
    Height: 576 pixels
    Display aspect ratio: 4:3
    Frame rate mode: Constant
    Frame rate: 25.000 fps
    Standard: PAL
    Color space: YUV
    Chroma subsampling: 4:2:0
    Bit depth: 8 bits
    Scan type: Interlaced
    Scan order: Bottom Field First
    Compression mode: Lossy
    Bits/(Pixel*Frame): 2.357
    Time code of first frame: 00:00:00:22
    Time code source : Subcode time code
    Stream size: 12.2 GiB (95%)
    Encoding settings: ae mode=full automatic / wb mode=automatic / white balance= / fcm=manual focus
    Audio
    Format: PCM
    Format settings, Endianness: Little
    Format settings, Sign: Signed
    Codec ID: 1
    Duration: 1h 0mn
    Bit rate: 1 536 Kbps
    Channel(s): 2 channels
    Sampling rate: 48.0 KHz
    Bit depth: 16 bits
    Stream size: 667 MiB (5%)
    Alignment: Aligned on interleaves
    Interleave, duration: 280 ms (7.00 video frames)
    Interleave, preload duration: 280 ms
    Jon Wendz replied 9 years, 2 months ago 4 Members · 15 Replies
  • 15 Replies
  • Chris Wright
    November 5, 2016 at 10:00 pm
    handbrake changes 2 fields to 2 frames so converting 25 interlaced to 50 progressive
    that is one way to deinterlace called “bob and weave”.
    does your video exporting have lines when there is fast motion?
    match your sequence frame rate to the 25 or…
    enable optical flow or you’ll get duplicate frames if you mismatch framerate
    I know in after effects, if you place a 25i into a 50p comp, it will fill
    each frame with a field so you keep the smooth high rate motion effect.
    if you deinterlace, it will become motion movie-like at 25p.
    In adobe media encoder right click interpret field order as lower field.
    then output codec video tab as progressive.
    I don’t believe premiere can do bob and weave export. Someone can hopefully correct me if I’m wrong on this.
  • Ann Bens
    November 6, 2016 at 2:22 pm
    Dont mess with the fields. PAL dv is LOWER.
    DV avi files are about 13 gig an hour which is the normal size. (get a larger disk)
    If you want to make dv footage suitable for Youtube.
    Make sure you have a matching sequence (there is a DV preset for this).
    Export to H.265/H.264/mp4 (progessive) making the framesize 788×576 par 1.0 en framerate 25 fps. (widescreen is 1050×576)
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Jon Wendz
    November 6, 2016 at 4:03 pm
    Thanks all.
    Chris:
    Yes there are exporting lines that appear! I’m slightly confused – what’s Adobe media encoder? Is that essentially the screenshot below? All I want to achieve is on compression, the same great fluidity that the raw avi provides.
    Ann:
    Perhaps I’m being stupid, but if I select match sequence settings, there’s no option for compression below (it’s all greyed out).
    Ignore the YouTube bit, that’s something I’ll do later down the line. For now, I want a nicely compressed MP4, retaining the extra-fluid nature of the original.
  • Chris Wright
    November 6, 2016 at 5:01 pm
    i anticipated that you had this error.
    here’s where to interpret footage and render progressive
    https://www.youtube.com/watch?v=eyz-87Uszek
    as for keeping the video look, you have two choices. uses optical flow as listed below for 50p
    Time interpolation settings using optical flow which might introduce artifacts
    https://helpx.adobe.com/media-encoder/using/export-settings-reference.html
    or try after effects with placing 25i (interpret fields lower) into a 50p composition and render out 50p no fields.(will put one field in each frames, ie. frame double
  • Jon Wendz
    November 6, 2016 at 5:08 pm
    Thank you. I’ll try the first option as I’ve never used AE before and I want to minimise my learning for now ? I’ll let you know how it goes!
  • Jon Wendz
    November 7, 2016 at 1:38 am
    Nailed it – I think.
    The HVEC 265 encoder has no option for lower/upper field. When I reverted to H264 the option was available!
    I wonder why it doesn’t support it in the former…
    Thanks again all 🙂
  • Jeff Pulera
    November 7, 2016 at 2:19 pm
    If exporting to H.264, you do not want any interlacing (fields). The .mp4 files will be watched on computers and tablets and their displays are always progressive, so you want to export Progressive.
    Jeff Pulera
    Safe Harbor Computers
  • Jon Wendz
    November 7, 2016 at 2:30 pm
    Thanks – so for clarification, that’s basically choosing “lower” in the render bit? That’s effectively deinterlacing it right? (Sorry if I’m a bit naive, this is all new to me).
  • Jeff Pulera
    November 7, 2016 at 2:34 pm
    No, if you choose UPPER or LOWER, that is INTERLACED video. You want Fields = PROGRESSIVE.
    You could just select the H.264 > PAL DV export preset, then manually change Field Order to Progressive.
    Jeff
  • Jon Wendz
    November 7, 2016 at 2:40 pm
    Perfecto! I’ll give that a bash tonight, thanks Jeff.
