Activity › Forums › Apple Final Cut Pro Legacy › A ProRes Question
  • A ProRes Question
    Posted by Jesse Schutt on May 11, 2010 at 2:16 am
    Hello all,
    I’ve got a quick ProRes question for you…
    I’m working on a project that was shot with a Canon XH-A1 in 30f. All the clips were captured via FireWire in the HDV 1080p30 preset. The edit is coming along quite nicely.
    My question is, should I switch to using ProRes instead of the HDV 1080p30 compressor? If so, how should I go about this?
    Jesse
    Jesse Schutt replied 16 years, 4 months ago 2 Members · 2 Replies
  • Neil Sadwelkar
    May 11, 2010 at 4:15 am
    You don’t need to. But you could consider setting the render codec to ProRes. That speeds up work when you do any effects.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Jesse Schutt
    May 12, 2010 at 3:52 pm
    Thanks Neil!
    So if I was planning on taking this into color and doing some corrections, the HDV codec will hold up just fine or would it be better to be in a ProRes codec instead?
