Activity › Forums › Adobe Premiere Pro › A png pic inserted into a title as a graphic doesn’t show
Posted by Yair Bartal on April 28, 2015 at 12:48 pmI’ve tried to insert the following png pic as a graphic into a title but the canvas stays empty:
Premiere Pro cc 2014.1
James Strawn replied 11 years, 5 months ago 3 Members · 7 Replies -
James Strawn
April 28, 2015 at 3:31 pm[Yair Bartal] the following png:
test1.png”
Just shows up as an empty (white) page to me at the link you shared.Software Quality Assurance – Digital Video at Adobe Systems
Yair Bartal
April 28, 2015 at 3:43 pm -
James Strawn
April 28, 2015 at 7:06 pmOK, I see.. PrPro is not recognizing the alpha in that image correctly. I believe the same thing will happen if you save it into another format which supports the alpha transparency, such as PSD.
A workaround is to put it on its own sequence and you can key it out and then use the sequence like a clip.
I’m not sure that it’s a problem with all transparency scenarios in the titler, or just certain ones. But I did play around with different save/compression options in PS and none of that seemed to make it work right in PrPro. It could be a know bug or a design limitation. I’ll look into it.
Here is another forum topic about the same (or very similar) thing:
https://forums.adobe.com/thread/1328475Software Quality Assurance – Digital Video at Adobe Systems
Robert Wentz
April 28, 2015 at 7:12 pm -
Yair Bartal
April 28, 2015 at 7:19 pmThanks James for testing it,
I’d appreciate your feedback if/when you have the time to further look into it. -
Yair Bartal
April 28, 2015 at 7:23 pmRobert, there’s no problem if I put the png pic directly on the sequence.
Only within the Titler I can’t see it.The resolution should be 1920X1080. I have no idea how you got 1609×905.
James Strawn
April 28, 2015 at 9:16 pmYes, I can repro it 100%. It’s a known issue, and I made sure there’s still a relevant report open for it. Still, it’s always good for users to report their own problems and feature requests here if possible:
adobe.ly/BugReportAnd if you’re interested, here is add’l info on how to submit feedback for PrPro:
https://forums.adobe.com/thread/878528
