Activity › Forums › Broadcasting › A lot of diferent question ..
  • A lot of diferent question ..
    Posted by Bruno Silva on December 8, 2009 at 11:55 pm
    Hello to all .
    So I started working in the area and I´m facing a lot of question . I´m a freelancer , so money is a importante factor in the next questions.
    My machine
    Phenom X4 965 – 4 * 3,40 Ghz
    8 Gb Ram – 1600 mhz
    Nvidia Quadro Fx 3800 ( 1 Gb Gpu, and a lot of other features)
    Windows 7
    Software ( Adobe , Sorezon Squeeze )
    My work is focus in Tv comercials.
    1- (HDTv , Broadcast Monitor, way to view the work looking for troubles)
    I use adobe workflow in my projects (Premier, After effects, etc) , first of all , I need a screen to test for flickers and color correction problems. Can I buy any Hd Tv and in premier, output to him and see the problems or do I need anything else like this https://www.nvidia.com/object/product_quadro_sdi_output_us.html and a broadcast monitor ? And If I only need a Hd tv, can you suggest some models that I can have in my desk?
    2- (Best codecs to use in my workflow, or plug in that I may get that improve image quality of the renders)
    At this moment we use a DV Cam that record Pal , and then they give me the footage uncompressed, or they use canopus codec , before thet give it to me. Then I normaly work on that footage and then export it to mpg2 using a preset that is the Dv Pal high quality in Premier with some changes, but I see that the picture loose a lot of quality in that process. How can I improve, and what is the best codec I can use. To export to Pal tv .
    Note: I have que adobe media encoder and Sorenson Squeeze
    3- (Dvd footage , using it on Premier )
    Sometimes I receve DVD that I need to take the footage and use it, but the problem is that it comes in Vob files and Premier doesnt read that files, so I need to convert them, what is the best way of doing it, and the best sofware to do it or the best way to work around this problem ??
    4 – (Footage in diverse formats)
    That question is a problem that I´m facing , I receved some Dvd of a company and some are 720p (16:9 ; 1024*720, )) and others regular Pal (4:3, 756*576), and of course they have diferent aspect ratio 1,44 and other 1,09. My final output need to be pal, what is the best way , program, solution , I can use to solve this problem?
    5- (Improving Workflow)
    I´m always looking for ways of improving my productivity and image quality of my works, so if you can suggest any software , plug in , codecs, Hardware, I can use that will improve I will be thankfull.
    …….Doing my best…..
    Bruno Silva replied 16 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
