Activity › Forums › Adobe Premiere Pro › A few beginner questions. Sorry :(
  • A few beginner questions. Sorry :(
    Posted by Frank Manno on March 10, 2009 at 12:47 pm
    I’m switching to Premiere CS4 from a different editing application and just want to ask a few things..
    1. Other than being able to change speed over time with keyframes, is there any difference in changing clip speed using time remapping or by changing clip speed/duration by CTRL-R?
    2. I need a fast way to make a clip 50% speed or 30% speed after I drop it on the timeline. Other than CTRL-R and typing ’50’ are there other quick ways?
    3. What’s a fast way to copy and paste a clip attributes? This is another thing I do a lot of. Can I select which attributes?
    4. Can I make the mouse wheel zoom into the timeline rather than the + and – keys?
    5. I need a hard ‘flash’ -from- white on clips. One way I can think of would be a white solid on a layer above a clip and a crossfade effect to fade the white away. Other than this, is there a better way?
    6. How can I create a white solid clip? Or a clip of any colour? I can only seem to create a black clip by going File -> New -> Black Video.
    7. Lets say I have a clip on the timeline amongst hundreds of others, and I want to see where this clip is in it’s original source file in the source monitor – (where I first selected the in/out points) How can I do this? Why? For the reason of possibly selecting other in/out points around that time frame
    Sorry for all these questions..
    -Frankie
    Eddie Lotter replied 17 years, 6 months ago 3 Members · 4 Replies
  • Mike Velte
    March 11, 2009 at 11:17 am
    1.Time Remapping wont ripple trailing clips or change audio.
    2. no
    3 no
    4 not that i know
    6 File>New>Color Matte. Dont use Black Video…there is a bug.
    7. Right click on the clip in the Timeline and choose”Reveal in Project” then double click the now highlighted clip in the source window to see the latest in-out points.
  • Frank Manno
    March 11, 2009 at 12:07 pm
    I said:
    >1. Other than being able to change speed over time with keyframes, >is there any difference in changing clip speed using time remapping >or by changing clip speed/duration by CTRL-R?
    Hi Mike thanks for your help!
    What’s the fastest way to apply a 50% time remap to a clip? Be it a shortcut or whatever? I need to fit this in as part of my workflow because it’s something I do a lot of: i.e, drop clip on timeline, add 50% slomo.
    -Frankie
  • Mike Velte
    March 12, 2009 at 10:43 am
    An alternate method would be to right/click on the clip in the Project Window and choose Interpret Footage and change the frame rate to half.
  • Eddie Lotter
    March 24, 2009 at 4:16 pm
    You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
    Cheers
    Eddie
