Activity › Forums › Boris FX Particle Illusion › A challenge for the pros
  • A challenge for the pros
    Posted by Dotan Baytman on November 10, 2006 at 10:03 am
    After seeing elvis latest tutorials i had an idea for a next tutorial
    for something i wonder how to do in a long time
    so maybe one of you pros here can have the answer
    what im trying to create is the effect seen in “blade”
    when he hits the vampires they turn into small fire particles and leave smoke after they vanish
    anyone tried it before?
    hope someone here can get a solution for that
    thanx in advance
    Dotan Baytman replied 19 years, 10 months ago 2 Members · 2 Replies
  • Thomash Lee
    November 11, 2006 at 1:23 pm
    Since I forget how the effect was done in Blade (I just remember the ugliness about the humans expanding and exploded with mass of blood after being injected with the virus or something else.) Roughly tried, but the result is less satisfied. If you are asking for the original disintegrating effect which the got-color-from-layer(model) particles turn into flame color, this shall NOT be done technically in pI3. The least thing I tried is that use only the get-transparency-from-layer. Since the transparency-over-life is assigned to this function, I have to set the visbility to fade out in the actual scene time graph. But still this ends up looking like the model is being covered by mass of particles and then disappeared behind the effect.
    https://www.geocities.jp/megidohk/flame-bu.zip
    (right click “save target as…”)
    This pI3 project file is lacking in the keyed model because I want to reduce the file size. Download the project file of Elvis’ disintegration tutorial. Then place my file in the same folder and import the “Elvis being hit” animation (total 65 frames) at the top layer. Remember to un-select the “hold last frame after sequence is finished”.
    https://www.geocities.jp/megidohk/burning-elvis.jpg
    (may look great if you’re in tight-black-leather hero or evil uniform blah blah blah~)
    Thomash’s music works and amateur artwork
    Wanna send me an email? Do it now!
  • Dotan Baytman
    November 12, 2006 at 12:02 pm
    I tried that and it doesn’t look like in the show and not realistic but still looks good
    can you explain a little what i need to adjust so i can use it on other videos?
    thanks allot for this file
    any other attempts guys?
