Activity › Forums › Adobe After Effects › a bit of clarity on edge mattes
  • a bit of clarity on edge mattes
    Posted by S. Marcotte on January 18, 2008 at 2:36 pm
    I built the finest track matte I could with my dvcpro50. It’s not going to get any better (new to the process, still tinkering) I’d like to blur the hard edges into the background plate.
    As I understanding it, I need an edge matte, one that overlaps BOTH foreground and background by a pixel or two (This is not a matte blurring operation.) What’s the best way to obtain said edge matte? (Or do I have it all wrong to begin with?)
    S. Marcotte replied 18 years, 8 months ago 2 Members · 2 Replies
  • Darby Edelen
    January 18, 2008 at 6:05 pm
    You can create an edge matte for an image in many different ways. What I would suggest is duplicating your matted footage, applying a Channel > Shift Channels effect with these properties:
    Alpha -> Full On
    Red -> Alpha
    Green -> Alpha
    Blue -> Alpha
    Then apply a Stylize > Find Edges effect and Invert it. This should give you a basic edge matte, from here you can blur it slightly and use Color Correction > Curves, Color Correction > Levels or Channel > Minimax to increase/decrease the range of the matte.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • S. Marcotte
    January 18, 2008 at 6:28 pm
    Will try. Thanks very much.
