Activity Forums Adobe After Effects a better film look
  • a better film look
    Posted by Chris Wright on January 21, 2009 at 8:39 am
    Andrew Kramer’s fps converter doesn’t warp enough to get smooth motion, so I took the time to make a smoother motion converter for 24fps film with 4 easy steps. Compare them.
    29.97 interlaced to 23.976 progressive
    1.Put 29.97i video in new 59.94 “start” comp so that timewarp can access both fields.
    2. add effect->time->timewarp speed at 60.545403%, filtering extreme,vector detail 20
    3. make new “output” comp 99 fps and drop “start” comp inside it with timestretch 60.545403%
    4. output “output” comp with separate audio layer from original video at 23.976 fields off.
    a note: if you import premiere project as layers, then you won’t need to worry about gloopy hard cuts.
    here’s a post to make technicolor without plugins!
    https://forums.creativecow.net/readpost/2/949550
    Chris Wright replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
