Activity › Forums › Adobe After Effects › _mov.mov folders being created on renders
  • _mov.mov folders being created on renders
    Posted by Max Haller on August 4, 2022 at 4:48 pm
    Hey guys long time no post, but I’m back with hopefully a simple question that’s been bugging me on some projects lately.
    In one of my projects I que’d 10 comps of lower thirds to render, and selected the output module on them all, and set the output folder. All pretty standard stuff. Except for a bunch (but not all) of them it created folders in that folder named ” _Mov.mov” When I double check the output setting the “Create sub folder” checkbox is unchecked. Any ideas how to stop this behavior?
    Thanks in advance.
    Max Haller replied 4 years, 1 month ago 2 Members · 2 Replies
  • Walter Soyka
    August 11, 2022 at 7:59 pm
    I’ve run into this before, too. I don’t recall exactly, but I think that it may have been caused by having an invalid render location set.
    Before rendering, select all your output modules, and choose Output To: Comp Name to reset the naming.
  • Max Haller
    August 12, 2022 at 3:28 pm
    Thanks for you reply Walter, I believe you’re correct about the cause. I’m not sure why it invalidates though. I don’t remember ever having this issue on older versions. I have comp name set as the default for the Output To: but I have noticed sometimes it puts the entire destination path as the name at first, and I have manually set it back to Comp Name.
