Activity Forums Adobe After Effects 946 stills when outputting to a targa sequence ????
  • 946 stills when outputting to a targa sequence ????
    Posted by Anthony Tripe on May 5, 2009 at 6:02 am
    AE 6.5 outputting my comp to a image sequence for editing in vegas. I’ve tried a targa sequence and a PNG sequence. It works but I end up with 946 stills in a folder. Is this normal? This doesn’t seem correct I’m not sure what to do now. i can set the length for all the stills and drop them in the time line – But what would be the length of each still. I’m kind of a moron so I’m sure I’m missing something here. There must be a setting I am missing that would put all the stills together in AE during Rendering?
    all the best
    anthony
    Paul Hennell replied 17 years, 4 months ago 2 Members · 1 Reply
  • Paul Hennell
    May 5, 2009 at 10:22 am
    I think you’re more confused by what you’re trying to do, rather then anything going wrong here, but no-worries, all can be explained.
    First – an image sequence is just that, a sequence of images. You’ll end up with a folder full of numbered images, each image being the equivalent to one frame. This is handy for all manner of reasons – from alpha channel support, to being able re-render and replace specific frames.
    When importing an image sequence (to AE) you have to tick ‘Image sequence’ (Bottom left of image selection screen) and then all the pictures will come in, grouped like a video. I’ve never used Vegas but I imagine there’s a similar option. Highlight the first image and look for it – it’ll be there somewhere.
    Alternately you can just export a video file. In the render queue output options – select ‘Quick time movie file’ or similar and you’ll get a single file movie. Note there’s a lot more to movie settings – if you don’t understand concepts like bit-rate, interlaced video and compression, you’ll probably get better quality from images. Still if you want to export to video use the output ‘Animation’ present. Tends to make a larger file – but it’ll look decent without having to fiddle with settings.
    Only in after effects do children get to pick and whip their parents.
    https://hennell-online.co.uk
