Activity Forums Apple Final Cut Pro Legacy 720/24p to 1080i60
  • 720/24p to 1080i60
    Posted by Will Sanderson on November 16, 2012 at 7:49 pm
    Hi all,
    I am encoding for broadcast for the first time and have been told to encode:
    DVCPro HD:
    Format: Quicktime Movie
    Compression Setting: DVCPro HD 1920x1080i60
    Compressor Native Raster: 1280×1080 (1920×1080)
    Frame Rate: 29.97
    Unfortunately, we have been shooting for web and haven’t thought about broadcast, so most of our footage is 24p. Is there a way using FCP/Compressor/MPEG Streamclip to create the required files?
    Every place I’ve seen has been suggesting a 3:2 pulldown using AE, but I unfortunately do not have the Adobe suite.
    Thanks for your help,
    Will
    Bret Williams replied 13 years, 10 months ago 4 Members · 5 Replies
  • Alan Okey
    November 16, 2012 at 8:43 pm
    You can add 3:2 pulldown using Compressor.
  • Will Sanderson
    November 16, 2012 at 8:56 pm
    How would I do the 3:2 pulldown using Compressor?
    I’m encoding the files using Compressor now with the exact settings I need. Will it automatically accommodate for the different frame rates?
  • Will Sanderson
    November 16, 2012 at 8:59 pm
    Thanks for the response, Dave. I wish I could afford After Effects, unfortunately I’m working with a highly limited budget… (i.e. $0).
  • Jerry Wise
    November 16, 2012 at 11:39 pm
    there is a “droplet” to add pull down using compressor. i think it was posted a year or so i believe. i’ve used it. works great for me.
  • Bret Williams
    November 17, 2012 at 4:30 am
    After Effects has a 30 day free trial. It is also rentable at $79 / month.
    But it has a learning curve. Easier and quicker would be FCP X. Drop your 720p24 in a 1080i sequence and export. Presto you’re done. It too has a 30 day free trial.
