6.5.4 no audio after playback
Hey Everyone,
I have two systems at the moment sharing media off a unity. One is mac and the other is PC. Everything is running fine but for some reason, the PC has an issue.
Whenever you load an audio clip into the source monitor it will play fine but as soon as you stop it or scrub to a different spot, no audio after that. The levels disappear as well.I am using a decklink for both systems but the PC seems to be the one having the issue.
HP Z420 Workstation
xeon cpu E5-1650 V2 @ 3.50 GHz
32gb of ram
windows 7 professional 64 bit.Any advice or help would be much appreciated. Thanks,
