Activity › Forums › Apple Final Cut Pro Legacy › 60i
Posted by Nicholas Toth on November 16, 2006 at 10:11 pm
Maybe this should be in basics, but how can I capture at 60i?
We recorded footage out of a DVX100 @ 60i and I can’t find the preset.
Nicholas Toth
Freelance Animator
nicholastoth.comIzoneguy replied 19 years, 10 months ago 5 Members · 10 Replies -
Jeremy Garchow
November 16, 2006 at 10:20 pm60i is also known as NTSC 29.97. Use the regular dv NTSC easy setup.
Nicholas Toth
November 16, 2006 at 10:22 pmDamn it I thought so. Sure hope time warp can fill in the missing spots.
Stupid interlacingThanks!
Nicholas Toth
Freelance Animator
nicholastoth.com -
Izoneguy
November 16, 2006 at 10:25 pmThe DVX100 will also shoot 30p,
try that.
And interlacing is stupid. -
Jeff Carpenter
November 16, 2006 at 11:34 pmCareful with 30p.
If you decide to later, 60i can be converted into 24p but you CAN’T turn 30p into 24p. You’re stuck with what you’ve shot in that case.
That’s not a thing that everyone needs to worry about, but just something to keep in mind.
Izoneguy
November 17, 2006 at 2:55 amYou can turn 30p into 24p, to turn 60i into 24p you would need to de-interlace which would give you 30p…..I do this all the time with 30p HD clips that I need to edit in a 24p timeline…
If I have to use 60i clips the de-interlacing step is sometimes a real resolution killer.
90% of my delivery is to progressive sources…the other 10% is TV spots but we still
edit progressive….. -
Izoneguy
November 17, 2006 at 3:03 amI think you are confusing 60p with 60i…..
60i is 29.97 fps…..de-interlace and it is 30p…
The HVX200 will shoot 720 60p
the DVX100 will only shoot 60i, 30p or 24p -
Gary Adcock
November 17, 2006 at 4:58 pm[izoneguy] “I think you are confusing 60p with 60i…..60i is 29.97 fps…..de-interlace and it is 30p…”
Look at it this way:
29.97 is the considered the frame rate for timing in Standard Def contentHD timing is always listed as 60 frames (720p) or 60 fields (1080i)
SO the time base for HD content in North America is 60i or 60p is 59.94 — so that it can easily be down-converted to SD at 29.97 (59.94 divided by 2)And de-interlacing an image does not necessarily make it 30p..
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Izoneguy
November 17, 2006 at 5:46 pm60i and 30p are both still 29.97
This is the confusion for so many….
24p is really 23.976….
If I shoot 30p either 480, 720 or 1080 the
frame rate will still be 29.97…..
When you de-interlace 60i you are throwing
away resolution…..
There are many ways to de-interlace video
but after you shoot progressive and edit progressive
you will wonder why people shoot 60i.
