Activity Forums Apple Final Cut Pro Legacy 5.1.2 is here .NM
  • Oliver Busch
    September 26, 2006 at 9:46 pm
    you’re right.
    weird.
    thanks for the info.
    Oliver
    September 26, 2006 at 10:00 pm
    The new P2 import is FANTASTIC!
  • Sean Oneil
    September 26, 2006 at 10:12 pm
    My first machine I tried, FCP will no long open after I installed the update. It just tells me a closed unexpectedly.
    Tried permissions, preferences, all the usual. No go. Be careful with this update.
  • John Christie
    September 26, 2006 at 10:24 pm
    Read Jeff’s post. Worked for me.
    Cheers
    John Christie
    Keyframes Editing
  • Dan Sparks
    September 26, 2006 at 11:00 pm
    Knock wood. Installed on my Mac Pro 2.66 w/BMD HD Extreme card. Reinstalled BMD drivers. Re-started Mac – Final Cut starts up fine – navigated to a project I just completed – it opened and plays fine. So far….so good.
    Dan Sparks
    Tricom Video
  • Craig Shields
    September 26, 2006 at 11:07 pm
    So what’s the deal if it doesn’t show up in your Software Update?
  • Shane Ross
    September 26, 2006 at 11:11 pm
    I too am THOROUGHLY IMPRESSED with the P2 Import ability. You can now vew BEFORE you import…and rename the footage, mark IN/OUT.
    Too good to be true.
    And the SCOPES! The SCOPES ARE AMAZING.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Tom Wolsky
    September 26, 2006 at 11:14 pm
    Are you using version 5.1?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Craig Shields
    September 26, 2006 at 11:27 pm
    Yep. Using 5.1 with FCS.
  • Aaron Neitz
    September 26, 2006 at 11:48 pm
    I just opened a 1080 project…. and over half the film comes up as “red/render.” No filters, no motion tab effects….. but there are other clips that play back… match frame and replace edit doesn’t fix it. 1080 clips play fine in source monitor…..
Page 2 of 6
