Activity Forums Adobe After Effects 4080×2300 project
  • 4080×2300 project
    Posted by Leo Jo on March 13, 2010 at 7:11 pm
    hi
    i’m doing after effects projects in a small production company
    and recently i’ve been asked to make some kind of looping video
    of videos circling a logo, now i have no problem with the graphics
    the only issue is that it’s supposed to be running on a huge screen
    4080×2300
    i told my boss i should just make it 1920×1080
    and they should find a way to project it bigger
    but he insists that i work with the measurements he was given
    it doesn’t make sense to me to work on a comp this size
    + i’m using renders from c4d
    appreciate the help
    Walter Soyka replied 16 years, 5 months ago 5 Members · 4 Replies
  • Jeremy Fabiano
    March 14, 2010 at 2:14 am
    correct me if im wrong, but isnt that 4k RED resolution?
    -Jeremy
    If you didn’t supply enough information I will start making assumptions. I’m usually wrong when I assume.
  • Alperen T. ayhan
    March 14, 2010 at 10:49 am
    you just have to know about the projector’s resolution.(1920×1080 , 1024×768, 800×600 , 2048×1536 whatever) If it is HD supported projector make your project in HD. If it supports more resolution 2K or 4K , open your comp project in 2K or 4K and then render. If the video will be aired on multiple monitors, you have to know about that hardware. But in my opinion HD or 2K is enough.
    Always cinema…
  • Maurice Jansen
    March 14, 2010 at 2:49 pm
    hmm
    wonder what projector it will be.
    as far as i know only Sony and JVC make a projector’s that can project
    resolution’s this high.
    SONY SRXT = 4096 x 2160
    JVC ILA = 4096×2400
    https://pro.sony.com/bbsc/ssr/micro-sxrdsite/cat-projectors/product-SRXT420/
    https://www.jvcpro.co.uk/jpe/en/global/product.3129.140.html
    i guess more important is how it will be playbacked.
    and maybe processed.(Spyder or Encore if it is a multiprojector edgeblended project)
    also viewing distance is a issue in how far you must go whit your resolution.
    grt
    Maurice
    People saying they don’t make mistake’s often make nothing at all!
  • Walter Soyka
    March 14, 2010 at 6:50 pm
    As the other posters have mentioned, resolutions of this size are possible with 4K equipment, video or LED walls, or blended projection.
    I’d suggest you inquire about the playback system, and find out more about the delivery specs, as there are many variables. Is the pixel space seamless, or are there display bevels or gaps to account for? What frame rate? What container? What codec? A single, full-raster file, or pre-split slices of the image?
    Walter Soyka
    Principal & Designer at Keen Live
    RenderBreak Blog – What I’m thinking when my workstation’s thinking
    Creative Cow Forum Host: Live & Stage Events
