Gilles Gagnon
January 22, 2014 at 10:03 pmThanks Graham,
I think I’ve used the correct workaround.
As suggested by you both, I ended up using the legacy text media generator and animating it with key frames. It appears to be providing the best output for rolling credits. I tried everything! Seems very sill to be using legacy plugins to get good quality output. Baffles the heck out of me.
I’m rendering the entire project right now… another 30min to go.
Where’s the wmv you’re referring to?
Gilles
Graham Bernard
January 22, 2014 at 10:08 pmI’ve tried to upload to the COW. Not working at present.
Glad you’ve got a way through. This breakup of text dogs all of us.
Grazie
Video Content Creator and Potter
PC 7 64-bit 16gb * Intel® Core™i7-2600k Quad Core 3.40GHz * 2GB NVIDIA GEFORCE GTX 560 Ti
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Gilles Gagnon
January 22, 2014 at 10:12 pmYes, I did look at a large number of posts in this regard.
Still baffled as to why a “pro” software like Vegas Pro doesn’t address this properly.
Gilles
Graham Bernard
January 22, 2014 at 10:41 pmO..K..Gilles me lad! As promised. It IS WMV and then re-coded by Bessie here . .. I used 12 Point Times with loads of SERIF and stuff that makes for a “Tweening-Nighmare”. It’s not as smooth as I’d wish, but that’s another story. The actual clarity isn’t to shabby:
Graham Bernard
January 22, 2014 at 10:42 pmO..K..Gilles me lad! As promised. It IS WMV and then re-coded by Bessie here . .. I used 12 Point Times with loads of SERIF and stuff that makes for a “Tweening-Nighmare”. It’s not as smooth as I’d wish, but that’s another story. The actual clarity isn’t too shabby:
Gilles Gagnon
January 22, 2014 at 10:49 pmThanks Graham me lad!
Well done! so which media generator did you use and do get as good result if you render as an mpg for DVD creation?Gilles
Graham Bernard
January 22, 2014 at 11:02 pmAs I asked, detail your rendering workflow, leaving nothing out through to DVD resolution. Are your using 720×576? What’s your PAR?
Grazie
Mike Kujbida
January 22, 2014 at 11:33 pmPixel Aspect Ratio. You’re NTSC so it’s either 0.9091 (standard) or 1.2121 (Widescreen)
