Activity Forums Apple Final Cut Pro Legacy 1440 vz 1920
  • Posted by Thomas Morter-laing on October 1, 2010 at 1:49 pm
    Ok, so I finally thought of what’s been bugging me. I understand that HDV is basically:
    1} 1920×1080 “squished” as part of its compression to fit onto tape
    2} when captured, it plays back at 1920×1080 through Quick Time
    2} in FCP it says the frame size is 1440×1080
    Right, now obviously 1440 by 1080 is actually a 4:3 resolution, hence why it plays back at 1920×1080 (which is correct 16:9). Now my question is, why then, if you make the canvas size 1920 by 1080 in FCP, does it pillar box the footage?
    Tom Morter-Laing
    Certified Apple Product Proffessional, 2010
    Degree; TV Production
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800).
    Jason Brown replied 15 years, 11 months ago 3 Members · 3 Replies
  • Rafael Amador
    October 1, 2010 at 2:30 pm
    [Thomas Morter-Laing] ” if you make the canvas size 1920 by 1080 in FCP, does it pillar box the footage?”
    Will fill the canvas.
    HDV uses HD pixels.
    1440 x 1080 HD pixels makes the same frame than 1920 x 1080 Squared pixels.
    Rafael
    http://www.nagavideo.com
  • Thomas Morter-laing
    October 1, 2010 at 2:59 pm
    Sorry that’s not quite what I meant, I mean if you set up the canvas to display 1920×1080 it DOES pillar box it. I understand the rectangular pixels hdv uses, but why does that not therefore fit into a 1920×1080 canvas?
    Tom Morter-Laing
  • Jason Brown
    October 1, 2010 at 3:02 pm
    1440 has a “PAR” – pixel aspect ratio. Meaning that each pixel has a shape, it isn’t square.
    There are several dimensions that are non standard –
    1440×1080 — 1280×1080 which both become 1920 when you multiply them by their respective PARs (1.33 and 1.5)
    960×720 is an anamorphic version of 1280×720 (multiplied by 1.33)
    In standard def, it’s the same way that the same dimensions (720×486 could become 16×9 or 4×3)…you don’t change the NUMBER of pixels, just the SHAPE.
    This always creates an issue when played back in a media player, like Quicktime…because you are trying to interpret non-square pixels…and if that flag isn’t embedded correctly, it won’t play back right. It’s all about knowing what your source is and interpreting it correctly.
    HTH,
    -Jason
