Activity Forums Adobe Premiere Pro 10.9.3 newMacPro GPU broken
  • David Brumbley
    May 22, 2014 at 11:24 pm
    I will. I’ll let you know what the results are in a couple hours.
  • David Brumbley
    May 23, 2014 at 4:59 pm
    I’ve installed the Nvidia driver and only had one glitch in the timeline with the GPU. When I went to export the timeline using maximum quality it crashed Premiere CC.
  • Ericbowen
    May 23, 2014 at 9:36 pm
    Can you export via Media Encoder? What happens if you don’t select Max Quality?
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
  • David Brumbley
    May 23, 2014 at 9:40 pm
    In export settings if “render at Maximum Depth” and “Use Maximum Render Quality” is off. Everything exports fine for me. If they are on the export freezes. I haven’t tried Media Encoder, but I’ll give it a shot.
  • David Brumbley
    May 24, 2014 at 1:17 am
    I tried Media Encoder and it spits out distorted frames.
  • Kevin Monahan
    May 28, 2014 at 6:41 pm
    Hi all,
    One of our customers over on the Adobe forum solved his issue. He said that several others he knows also solved it.
    The new MacPro had faulty GPUs.
    Here is the link: https://forums.adobe.com/message/6410739#6410739
    Those experiencing this issue may want to bring their MacPro to the nearest Apple Store/Genius Bar and have their machine checked out.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Ben Silberfarb
    May 29, 2014 at 1:24 pm
    Attached is a screen shot typical of the type of crash you get with AMD FirePro cards on the new Mac Pro with 10.9.3. Having spent many hours on the phone with both Apple and Adobe I can confirm that it is an acknowledge bug that will only be fixable upon the next update by Apple and/or Adobe. A lot of editors are in a world of hurt right now.
  • Ericbowen
    May 29, 2014 at 3:28 pm
    So far word on the 10.9.4 Beta fixes the issues with Premiere.
    Eric-ADK
    Tech Manager
  • Al Levine
    May 29, 2014 at 8:03 pm
    I’m also being told that 10.9.4 will fix this issue.
  • Kevin Monahan
    May 29, 2014 at 11:00 pm
    Thanks for reporting on that, Eric.
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
Page 3 of 7
