Activity › Forums › Apple Final Cut Pro Legacy › 10.5.8 warning
  • Posted by Chris Paul on August 6, 2009 at 7:01 pm
    After updating to OSX10.5.8 this morning my Final Cut 7 system has suddenly become unreliable. Playback stall, stutters and shows the spinning rainbow wheel. OSX has crashed twice in the last 30 minutes. FYI.
    Chris Paul
    POV
    Rafael Amador replied 16 years, 10 months ago 8 Members · 10 Replies
  • 10 Replies
  • Chris Paul
    August 6, 2009 at 7:08 pm
    It looks like my LaCie eSATA array or card does not work well under 10.5.8. I changed to my fiberchannel array and the FCP issues have disappeared.
    Chris Paul
    POV
  • Chris Paul
    August 6, 2009 at 7:12 pm
    Spoke too soon- playback is OK but OSX is still locking up.
    Chris Paul
    POV
  • Zane Barker
    August 6, 2009 at 7:21 pm
    How did you run the 10.5.8 update? I always recommend running the combo update not the smaller update.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Chris Borjis
    August 6, 2009 at 7:26 pm
    I always recommend not auto updating. and only update if there is a feature/fix you need.
    not worth the trouble otherwise.
    my 002 cents.
  • Jeff Jangeer khan
    August 7, 2009 at 10:43 am
    Did you do the Repair Disk Permissions after updating?
  • Brian Conner
    August 7, 2009 at 1:13 pm
    I always use the Combo Updater, too. However, there seems to be a permissions problem with the Combo Update this time. If you Repair Permissions after installing the v10.5.8 Combo Update, in the list of repairs, you can note that a lot of files are having their permissions changed to ?——— and that might not be a good thing.
    https://discussions.apple.com/thread.jspa?threadID=2106528&tstart=0
    FWIW.
    Brian Conner
  • Chris Paul
    August 7, 2009 at 6:06 pm
    You are correct about the permissions error problem. The current consensus is that the combo update should be applied twice before repairing permissions. This still doesn’t solve all of my issues so I will restore the previous version from my backup.
    Chris Paul
    POV
  • Mark Maness
    August 7, 2009 at 6:54 pm
    Good deal!
    You have a backup!
    You get a cookie!
    Its amazing how many out here don’t backup before doing ANY update. Glad to hear that you are not in that boat.
    To everyone else out there who doesn’t know this… ALWAYS backup before ANY update.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Claus Frederiksen
    November 8, 2009 at 10:12 am
    Same thing happened to me – running FCP 6.0.6. Still no answer from Apple…
    Kind regards from Denmark,
    Claus Frederiksen
    http://www.frederiksenproductions.dk
  • Rafael Amador
    November 8, 2009 at 11:38 am
    Run DiskWarrior or TechTools.
    Rafael
    http://www.nagavideo.com
