\\\Dynamics/// – having trouble with gravity and multiple objects !!!
Hello,
I’m making a short animation to show the functioning of an object.
A ball follows a rail downwards, falls on a receptacle that is pivoting, which should drop the ball
on the base of the object when rotating.
It works perfectly until it arrives on the receptacle, but I make it rotate, the ball stays sort of “attached” to it
as if gravity wasn’t working anymore.
Would anyone have an idea, of how I could fix this ? Does it have to do with the dynamics of the ball itself
or of the receptacle. I’ve tried every option available as far as I know, and I would reeeeally appreciate
someone’s help 😉
Here is the video on which you will see what I mean https://www.youtube.com/watch?v=pXx2InPluiI.Thanks !!
