Activity › Forums › Adobe After Effects › Zooming in makes vector path pixelated
  • Zooming in makes vector path pixelated
    Posted by Abd el ghafour Mohie on June 15, 2020 at 7:09 am
    When I copy/paste an object from Illustrator or even import it as an Illustrator file and then turn it into vector shapes then I zoom in on it it gets very pixelated, while in Illustrator it maintain its sharpness no matter what.
    After Effects 100% Zoom:
    After Effects 800% Zoom:
    Illustrator 800% Zoom:
    Eric Santiago replied 6 years, 3 months ago 4 Members · 5 Replies
  • Tero Ahlfors
    June 15, 2020 at 8:26 am
    Zooming the viewer only scales up the view of the comp. So, for example, at 1920×1080 that 800x zoom is not pixel per pixel crisp. Also no one is viewing stuff at 800x zoom.
  • Richard Garabedain
    June 15, 2020 at 3:00 pm
    your mouse wheel does not zoom the camera…it only blows up the screen..
  • Abd el ghafour Mohie
    June 16, 2020 at 3:51 am
    Thanks for your reply.
    But, why can’t After Effects have the same behaviour as Illustrato as seen in the image above?
  • Tero Ahlfors
    June 16, 2020 at 6:38 am
    Because you’re not zooming the vector information. You’re zooming into the rasterized comp view.
  • Eric Santiago
    June 16, 2020 at 12:04 pm
    Illustrator is a vector design app.
    The app will refresh the lines smoothly at all times (well as best it can).
