Activity › Forums › Apple Final Cut Pro Legacy › Zooming in (ie Scale up) on AVCHD for a DVD
  • Zooming in (ie Scale up) on AVCHD for a DVD
    Posted by Brian Thomas on November 11, 2011 at 4:04 pm
    I have some PAL AVCHD clips which I took with my Panasonic TM300 and in the Browser they show as Frame Size 1920 x 1080, 25 fps, Apple ProRes 422, 14.7 MB/Sec, Pixel Aspect Square, Field Dominance (Upper (Odd)
    My end product will be a normal DVD.
    My question is how far can I reasonably zoom in (ie, the Scale parameter under Basic Motion) and still have a reasonable image on the (Standard Definition) DVD? Is there a simple formula? Might a scale of 200 be OK? A bit more?
    Many thanks in advance for any help.
    PP 5.5.0, FCP 7.0.3 iMac 24 3.06 4GB OSX 10.7 MBP 17″, 2.3 GHz 8GB. Near Geneva, Switzerland
    Brian Thomas replied 14 years, 10 months ago 2 Members · 2 Replies
  • Chris Tompkins
    November 11, 2011 at 4:53 pm
    Well if you zoom in while in a 1920×1080 sequence – you will experience degradation and quality loss, even when viewing the SD-DVD.
    If you have a fair bit of zooming to do and ONLY going to SD-DVD, then consider working in a SD sequence. That way you have lots of play to work in and around the HD clips…
    Chris Tompkins
    Video Atlanta LLC
  • Brian Thomas
    November 11, 2011 at 5:07 pm
    Ah – didn’t think of that, I’ll give it a try. Thanks!
