Activity › Forums › Apple Final Cut Pro Legacy › zooming in FCP
zooming in FCP
Posted by Simon Bronson on June 19, 2005 at 11:22 pmI know this has been asked before but I an unable to get a successful enlargement of a clip without it going soft, despite the footage being uncompressed digital betacam played through my decklink card. Even if I’m using round (even) numbers as soon as I go past 100% scale my image is blurry. I’ve been using After Effects for enlargement so far. Is there another way other than the Motion>Scale option?
thanks in advance,
simon
Simon Bronson replied 21 years, 3 months ago 4 Members · 5 Replies -
Graeme Nattress
June 19, 2005 at 11:29 pmThe scaling algorithms are improved i n FCP5, but although downscaling is vastly improved, I don’t see much better on upscaling. AE or Shake has better scaling than FCP – remember FCP is an editor, not an effects package.
Graeme
– http://www.nattress.com – Film Effects for FCP
Bouncing Account needs new email address
June 20, 2005 at 12:35 pmWith all due respect to Mr. Nattress (he’s the best).
But, I have been producing and editing video for decades and have used all sorts of digital effects gear over the years (some units costing upwards of $100,000.00) and I get as good a results (in many cases, BETTER) in FCP as I ever got with the high-end gear.
1. You must render all effects to get full quality.
2. You must only check for QUALITY on an externtal video monitor, not on the computer monitor.
3. You must make sure that if you adjust the position of an image that the VERTICAL position is placed on an EVEN (not odd) INTEGER (no “percentages”).Of course, if you want to zoom-in very “far”, you want a to use a larger, scanned image (1440 x 1080??)
But, I scale even 720×540 images in FCP up to 160% or so and, depending on the image, get very good results.HOWEVER, if you are trying to zoom-in on a moving-video CAMERA image, the smaller the zoom-in, the better.
Graeme Nattress
June 20, 2005 at 12:52 pmMatte, the blurryness the original poster could be seeing could indeed be FCP playing one of it’s many nasty tricks that you advice will solve, however…. The scaling in FCP is, although improved in FCP5, still way below the quality of, say, Shake or After Effects, or any other compositing package I know other than perhaps Motion, which although I’ve not checked Motion2, wasn’t terribly good in Motion 1.
So yes, absolutely go with Matte’s advice to see FCP’s scaling at it’s best!! But if that’s still not good enough for you, then that’s just because the scaling in FCP is lame.
Thanks Matte for filling in the piece of the picture I missed in my speed to castigate the abilities of FCP. Appreciated.
Graeme
Gunner Jones
June 20, 2005 at 5:33 pmIn addition to what Matte said, you need to change the motion filtering quality to Best in the Video Processing tab of the Sequence Settings dialog for good results. You should also have the Full and Preview Bars checked in the Sequence > Render menus.
This is getting to be a very common problem.
O&O-Gunner Productions
FCP-Avid-After Effects -
Simon Bronson
June 20, 2005 at 10:14 pmThanks for the response guys, unfortunately the scaling is still not sharp enough for the crisp video I’m using. Before I upgrade to FCP 5 I’ll continue to upscale my video through after effects for now.
cheers,
simon
