Zoom Keyframes Continued Through Multiple Clips in Premiere CS6
I’m doing a time-lapse with an image sequence as one long clip.
This long clip is cut into 3 clips, A – B – C with cross dissolve transitions between.
I would like to do a zoom out using keyframes starting at frame 1 of A at 100%
The zoom should go to the end of clip C to 75%I tried nesting to no avail. I’ve hacked a solution by exporting then applying the keyframe zoom to the exported clip… very kludgy.
Any suggestions on working with the original A-B-C clips?
Thanks in advance (and I hope I made myself understandable)
