Activity › Forums › Adobe Premiere Pro › Zoom in and zoom out
  • Zoom in and zoom out
    Posted by Soumendra Jena on March 6, 2014 at 3:16 am
    I have seen some videos and also in movies, the footages like the disco or pub dancing scenes, they do a quick zoom in and zoom out too and then back to normal .
    How is that done ?
    Is that something which is done in Post processing and how
    Because, camera zoom in zoom out cannot be that smooth as it depends on the hand movements, which will never be even for the moves.
    Michaël Leclézio replied 12 years, 2 months ago 5 Members · 5 Replies
  • Joe Barta iv
    March 6, 2014 at 2:04 pm
    It is also called a Pop Zoom. Usually it is a manual zoom on the camera. Quickly rotate the zoom ring back and forth from full wide to full tele and back by hand.
    Bars & Tone
    SALUTE!
  • Soumendra Jena
    March 6, 2014 at 2:16 pm
    Its tough for manual.
    Any premiere pro plugins or effects available ?
  • Jeff Pulera
    March 6, 2014 at 3:10 pm
    Select a clip on the timeline, then go to the Effects panel. Each clip already has “Adobe Motion” effect on it. Use the “Scale” function to “zoom in/out”. You will need to use Keyframes to animate the scaling up/down. Plenty of online tutorials on how to use keyframes, probably some right here on the Cow.
    Jeff Pulera
    Safe Harbor Computers
  • Ann Bens
    March 6, 2014 at 11:05 pm
    Cut the clip where you want the pop zoom.
    Drop the Cross Zoom transition on this cut.
    See if that will work for you.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Michaël Leclézio
    July 6, 2014 at 10:34 pm
    thanks Ann. that was helpful!
